Date/Time: Sun, 05 May 2024 10:29:32 +0000
Alert condition to draw a Vertical line on New High/Lows using the Daily OHLC study
View Count: 608
[2022-06-12 01:17:15] |
Dan the Man - Posts: 82 |
Hi, If I used the Daily OHLC study what would be the Alert condition to have a vertical line drawn at a new daily high/low? Or, is there is another way to have a vertical line drawn at a new daily high/low? As per the attached screen shot Kind Regards, |
Vertical line.png / V - Attached On 2022-06-12 01:15:45 UTC - Size: 47.17 KB - 133 views |
[2022-06-12 08:46:32] |
User431178 - Posts: 413 |
Here is an example of one way you can do this.
VerticalLineHighLow.Cht - Attached On 2022-06-12 08:46:01 UTC - Size: 3.77 KB - 128 views |
[2022-06-12 16:09:04] |
Thanks User431178 ! You pointed me in the right direction. When I try to duplicate your setting on my chart the "Color Bar Based on Alert Condition", for some reason, I'm not getting the same results. I had to use the "Color Background Based on Alert Condition" but still struggling. Besides plotting Daily High/Low on the ES, I would also like to plot a Daily High/Low on on the TICK in chart range 2 If I could encroach on you would you be able to look at this. I attached your cht file with a copy of my chart next to yours. Is there a way to remove the previous (old) Daily High/Low as the day develops? Kind Regards, |
VerticalLineHighLow.Cht - Attached On 2022-06-12 16:07:18 UTC - Size: 9.47 KB - 107 views |
[2022-06-13 11:16:06] |
I added another copy of your chart and changed some settings so you can compare.
VerticalLineHighLow.Cht - Attached On 2022-06-13 11:15:59 UTC - Size: 14.14 KB - 118 views |
[2022-06-13 11:32:50] |
Also have a look at this study: Daily OHLC - Single Point Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-13 16:56:12] |
Thank-you User431178 and Sierra ! Working with the settings Kind Regards, |
