Date/Time: Sun, 05 May 2024 04:10:16 +0000
sc.TradeServiceAccountBalance no longer supported
View Count: 387
[2022-06-11 16:47:34] |
Marmany - Posts: 303 |
Updated to v 2400 and in release note it states: The following ACSIL structure member variables are no longer supported: sc.TradeServiceAccountBalance, sc.TradeServiceAvailableFundsForNewPositions. You need to to use the int sc.GetTradeAccountData(n_ACSIL::s_TradeAccountDataFields& r_TradeAccountDataFields, const SCString& TradeAccount) function instead. Not able to work out how to access account balance using sc.GetTradeAccountData. Please give an example of code required. However the function sc.GetTradeServiceAccountBalanceForTradeAccount("Act No") gives the correct value. Why is this not mentioned in the release note? Please advise |
[2022-06-14 13:49:54] |
Sierra_Chart Engineering - Posts: 14224 |
We will put together an example.
[2022-06-15 09:36:40] |
Here is the documentation: sc.GetTradeAccountData() However the function sc.GetTradeServiceAccountBalanceForTradeAccount("Act No") gives the correct value. Why is this not mentioned in the release note? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
