Date/Time: Tue, 30 Apr 2024 00:30:49 +0000
ASCIL missing fields like DaysPerBar
View Count: 365
[2022-06-11 16:29:18] |
DabbaDo - Posts: 146 |
I'm getting back into ASCIL coding after a long absence, and I'm confused. At ACSIL Interface Members - Variables and Arrays I see documentation for sc.DailyDataBarPeriod and sc.DaysPerBar. But those names don't appear in the ACS_Source anymore (Version 2400 and even 2296) I see they did exist in version 1575 Is the documentation just out of date? Or am I missing something? Thanks, Dale |
[2022-06-11 17:12:03] |
User431178 - Posts: 412 |
sc.GetBarPeriodParameters() You can use this function instead. |
[2022-06-12 13:22:33] |
Very helpful, thank you.
[2022-06-13 13:55:32] |
These old ACSIL members have been removed from the documentation.
