Date/Time: Sun, 05 May 2024 01:53:19 +0000
Trade Volume Triggered Stop internal logic
View Count: 445
[2022-06-09 16:05:32] |
User392433 - Posts: 41 |
Is the volume trigger based only on the volume of the set stop price or total volume for symbol after hitting the stop price. For example, if this stop is at 10 and bid is at 9 and ask 10, then will this stop be based on the volume at both 9 and 10 or just 10, and if 10 gets hit but then market ticks down to bid 8 ask 9 will the volume trigger get reset? Will those prices also count towards volume? Also, is this a server side stop? Thanks |
[2022-06-13 20:23:21] |
Sierra_Chart Engineering - Posts: 14224 |
We are updating the documentation now to explain this.
[2022-06-13 20:28:50] |
We looked into this, and the documentation already explains this: Order Types: Trade Volume Triggered Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
