Date/Time: Wed, 14 Oct 2026 17:57:04 +0000
Relative volume not operating properly
View Count: 780
| [2022-06-09 13:56:56] |
| User213504 - Posts: 124 |
When I opened the program this morning the Relative Volume study looked really weird. I wish I had a pic of when it was operating correctly but I have one now. The readings are just incorrect. There is no percentage and the coloring is wrong.
| [2022-06-09 15:45:40] |
| John - SC Support - Posts: 48204 |
What you are showing for the subgraphs is the default coloring for that study. If you had modified it, and then removed it and put it back on without changing the defaults, then it would be the way it is showing now. You will just have to reconfigure the study to be the way you want it. Also refer to the following information on how to set defaults for a study: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
