Date/Time: Sun, 11 Oct 2026 16:49:30 +0000
how do you change the symbol on time and sales
View Count: 801
[2022-06-08 21:16:18]
Mr.Lucifer - Posts: 9
as title states
[2022-06-08 21:36:25]
John - SC Support - Posts: 48169
You can not change the symbol for Time and Sales directly. You first have to open a chart for the symbol you want and then open a Time and Sales window for that symbol. Refer to the following:
File Menu: Open Time and Sales Window (File)
[2022-06-08 21:59:28]
also im trying to extend price retracement tool and it doesn't extended
[2022-06-09 14:14:41]
Right click on the drawing and select Chart Drawing Properties. Select the Options tab and enable the option for Extend Left. Then try the same for Extend Right. Let us know if are not able to extend using either of these options.
If you do continue to have issues, then it is most likely a corrupted drawing and removing it and putting on a new one should resolve the issue.
