Date/Time: Sun, 11 Oct 2026 16:50:02 +0000
Ordenes dentro de la plataforma
View Count: 711
[2022-06-08 18:31:15]
User192815 - Posts: 3
Buen dia, tengo un problema con la plataforma que desactivo la opción de trade simulation para operar con la cuenta real, pero cuando coloco una orden limite en el mercado la plataforma automaticamente se me pasa a la cuenta de simulación y no me está dejando operar con la cuenta real.
[2022-06-08 20:47:10]
John - SC Support - Posts: 48169
From Google Translate:
Good morning, I have a problem with the platform that deactivates the option of trade simulation to operate with the real account, but when I place a limit order in the market, the platform automatically switches me to the simulation account and it is not letting me operate with the actual account.
Typically, this occurs because your Current Selected Service is set to SC Data - All Services and not connected to your live trading account. But our servers are showing that you are connecting to CQG. In which case, you should not be having this issue.
First thing is to check this setting. Select Global Settings >> Data/Trade Service Settings and on the tab for Main Settings make sure the option for Current Selected Service is set to CQG WebAPI.
If it not set to CQG WebAPI then follow these instructions to get connected to your CQG account:
CQG Trading Platform Service: Setup Instructions
