Date/Time: Wed, 18 Nov 2026 09:39:22 +0000
Add Triangle Offset Right for Candlestick
View Count: 793
[2022-06-08 15:30:35]
Bedhog - Posts: 187
Hello Team,
May I please have a Triangle Offset Right for Candlestick for the Color Bar Based On Alert Condition?
I'm using the Square now with modest success... it would be even better as a directional indicator instead.
Thank you!
imageSQUARE-OFFSET-RIGHT-FOR-CANDLESTICK.PNG / V - Attached On 2022-06-08 15:29:25 UTC - Size: 28.54 KB - 359 views
[2022-06-08 16:34:44]
There is an existing subgraph for Triangle Right Offset for Candlestick. Refer to the following:
Chart Studies: Triangle Right Offset for Candlestick (ACSIL: DRAWSTYLE_TRIANGLE_RIGHT_OFFSET_FOR_CANDLESTICK)
But, this is not exactly what you want, as it points to the right. Still, you could use this in combination with the square to have one designate an up and the other a down.
We do not know when we would be able to add Triangle Up/Down Right Offset for Candlestick (which would be what you would want).
