Date/Time: Wed, 14 Oct 2026 17:57:53 +0000
DOM price lines
View Count: 1029
| [2022-06-08 13:19:21] |
| manta_rochen - Posts: 6 |
hello there, i cannot figure out how to add more price lines on my DOM. i'd like to make it wider. thanks. |
| [2022-06-08 16:10:26] |
| John - SC Support - Posts: 48204 |
Sorry, but we are not sure exactly what you are looking for, particularly in terms of "wider". You can not change the width of the Price Ladder itself - this is fixed based on the displayed information. If you want to change the way the prices are displayed (more or fewer decimal places), then refer to the following setting: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) If you want the prices to be at specific increments, then refer to the following: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Otherwise, please give us some more information and possibly a marked up image of what you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-08 19:52:30] |
i'd like to put more prices lines on the ladder. now it shows 24 price levels, i'd like to see at least the double, 50 i'm not talking about increments here, but price levels. |
| [2022-06-08 21:16:05] |
We are not sure which of two things you could be referring to. 1) You need to use the Scale Increment as we mentioned above to force the display of more price levels. For instance, if your typical scale is showing prices every 0.25, then enter a Scale Increment of 0.2 or 0.1 and see how that looks for you. 2) If you are not getting the range of the data you want, then you need to compress the price scale. Refer to the following: Working With Charts: Interactive Scaling: Compress/Expand Vertical Scale, Move Chart Up and Down For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-09 16:59:33] |
ok done, i finally solved it, thanks )))
