Date/Time: Thu, 08 Oct 2026 15:07:54 +0000
NQ Futures chart won't show up
View Count: 852
| [2022-06-07 19:27:14] |
| User850090 - Posts: 27 |
Hello. Today I can not open only charts with NQ futures. Please help. Thanks
| [2022-06-07 21:06:03] |
| John - SC Support - Posts: 48151 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-07 23:50:27] |
It is NQM22. But after I open it I can not disconnect and connect data because it will freeze up. So I can only close it and restart sierra.
| [2022-06-08 15:22:06] |
We have responded to this in this thread: charts keep freezing up Please do not post more than once for an issue. It only slows things down. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
