Date/Time: Wed, 08 May 2024 00:55:30 +0000
Percent Change Chart
View Count: 2646
[2014-05-01 19:13:46] |
infpz - Posts: 826 |
Is it possible to set up a chart (ideally with overlays) where the charts all start at ZERO - and move from a single point based on percent change? Basically, if I wanted to see ES, NQ, YM, and TF on 1 chart, relative to each other - based on % change up or down from a given point. See the image attached, the key point is everything starting in the same spot.
[2014-05-02 19:32:33] |
This can be done by using this study: Percent Change Since Open You can then overlay all of these on the same chart by using the Study/Price Overlay study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-05 12:17:41] |
Thanks, but at this moment the ES is down .28% per the quoteboard, and this indicator value shows it down .44%. I have the chart set to open at 17:00:00 and end at 16:15:00. In Settings and Inputs I have "Trading Day Start Time" set as the only input value. Any suggestions? |
[2014-05-05 16:41:56] |
The calculation is relative to the opening price of the day. Knowing that, is the calculation correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-05 16:49:51] |
No - the quoteboard is right though. Right now the ES is up 4.00. Prev Close was 1872.50. So it is up .0021, the quoteboard shows +.21% and the chart shows +.00533 or .53%. So it appears the chart is off whereas the quoteboard is correct.
[2014-05-05 16:59:22] |
The calculation is done relative to the open price at 17:00:00 within the chart itself. Not the prior days close. Understanding that, is the calculation correct?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-05 16:59:46
[2014-05-05 17:02:08] |
yes it is. thank you.
