Date/Time: Sun, 19 May 2024 08:29:24 +0000
Version 1131
View Count: 900
[2014-05-01 17:44:24] |
Carl71 - Posts: 125 |
There is a serious issue when you select Scale Range Automatic in the Trade DOM
[2014-05-01 17:55:23] |
video |
DOM ISSUE.avi - Attached On 2014-05-01 17:55:03 UTC - Size: 3.6 MB - 337 views |
[2014-05-01 18:10:19] |
Using Scale Range Automatic for a Trade DOM may not work correctly. Whatever issue would arise, if any, would not be specific to 1131. Why are you using Scale Range Automatic? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
