Date/Time: Sat, 31 Oct 2026 23:55:02 +0000
New Chartbook settings I want?
View Count: 1095
| [2022-05-31 20:40:56] |
| User628616 - Posts: 132 |
everytime i start a new chart it opens with the chart i attached. how do i setup it up to where everytime i open a new chart it opens with the settings i want(candlesticks instead of ohlc, etc)
| [2022-06-01 14:27:35] |
| John - SC Support - Posts: 48377 |
There are two ways to do this. First, you can save a default for the Days to Load, Bar Period, and Draw Style. Refer to the following: Chart Settings: Save Days to Load, Intraday Bar Period, Graph Draw Type as Default (Chart >> Chart Settings >> Chart Data >> Chart Data menu) The second is to use a template by having a chart setup the way you want and then duplicating that chart to create a new one. Refer to the information here: Using Chart Templates: Duplicating Charts / Template Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-23 12:43:30] |
im running 2276 and the new version is 2405, after updating to newer version, how do i get my chart settings window to look like the way the older versions featured it, i attached a pic of the example
| [2022-06-23 13:27:12] |
This is not supported. Refer to: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow Also refer to this video: https://videos.sierrachart.com/Settings_Windows_Interface.mp4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
