Date/Time: Sun, 05 May 2024 02:17:57 +0000
Interactive Brokers Stock CFD's
View Count: 1078
[2014-05-01 07:26:44] |
User22153 - Posts: 46 |
Hello Support, I can't get Stock CFD's to load on Sierra Charts. What is the symbol format for Stock CFD's, because you guys have put Indices as an example. It will be helpful if you can add the stock crd's example on that section as well. Thanks |
[2014-05-05 06:39:38] |
We cannot give you a definitive answer on this because we do not know. The CFD format here should be what you need to use: http://www.sierrachart.com/index.php?l=doc/IBSymbols.html#CFDFormat Each of the parts of the CFD symbol separated by hyphens, is a part that is set into the IB contract structure when requesting market data and submitting orders. So you have full control over the symbol parts sent to Trader Workstation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
