Date/Time: Fri, 26 Apr 2024 14:48:13 +0000
[Programming Help] - Charts updates only every 2 seconds
View Count: 323
[2022-05-23 14:07:51] |
lovelivelaught - Posts: 47 |
Hello On Friday at the end of day I cleared some data files in my Sierra folder as my Windows(C) was running out of free storage. I assume when I cleared some accumulated data that was related to trading log I deleted something else as today it is causing a delayed "paused" (every 2 second) chart update and even moving chart windows are slow. I need help with that please. I did not cleared my recycle basket yet in case if I have to restore files. Heads up - I am bad with all software language and in case if you have to log in my computer to find a problem it might be a better and faster solution or just call me and guide me instead of texting back and forth. Thank you on advance! |
[2022-05-23 16:21:52] |
Update To make it easier for myself I downloaded a new SierraChart software on my Data(D) disk as I did not have enough space on my Windows (c). I copied all files in the software that I had a problem with (in Windows(C)) and pasted to a new software Data(D) . it seams like it is working fine now. Please let me know that it will work so I can uninstall Sierra software on my Window(C) Thank you in advance! |
