Date/Time: Sat, 18 May 2024 19:51:01 +0000
Chart trading Eurex orders problem
View Count: 965
[2014-04-30 12:23:07] |
User70856 - Posts: 1 |
Dear Sirs, When I submit to IB a limit order via Chart Trade on Eurex (Bund futures)the order shows up on IB TWS but it needs to be manually transmitted via TWS before being considered an open order...usually with CME contracts any order I submit via Chart Trade is automatically an open order in TWS without need to press the TWS transmit button....any idea how can I remove this limitation on Eurex contracts which slows down my order entry process? Thank you for your kind feedback Diego |
[2014-04-30 15:32:14] |
You need to contact IB about this. There is something you need to change on Trader Workstation and we do not know what.
