Date/Time: Fri, 19 Aug 2022 16:41:01 +0000
Attached order offset modification setting no longer working
View Count: 170
[2022-05-19 21:37:40] |
User480347 - Posts: 8 |
Awhile ago something happened and now my attached orders are adjusting when parent order is adjusted. The "adjust attached orders to maintain same offset on parent modification" is NOT selected and was previously working.
[2022-05-20 10:19:50] |
Sierra_Chart Engineering - Posts: 3091 |
So you are using CQG? Should not be any problem with this. If that option you describe is set to No, then the attached orders should not be modified. We do not know what the issue is in your case. Do you notice this issue in Trade Simulation: Trade Simulation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-20 10:20:28
[2022-05-20 13:58:39] |
Yes I'm on CQG. It is occurring on simulation too. That is actually where it first started, then eventually it was happening during live trading as well. |
[2022-05-26 20:02:57] |
Is there anything else I can check to get this working properly again?
[2022-05-27 07:21:53] |
We have identified the reason for the issue and we will implement a solution in a new release coming out today.
[2022-05-27 12:56:51] |
To solve this update to the latest prerelease following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
