Date/Time: Fri, 26 Apr 2024 13:03:00 +0000
PositionData.PriceHighDuringPosition And PositionData.PriceLowDuringPosition
View Count: 291
[2022-05-18 16:36:12] |
Richard Chinn - Posts: 28 |
RE: s_SCPositionData PositionData; sc.GetTradePosition(PositionData); PositionData.PriceHighDuringPosition AND PositionData.PriceLowDuringPosition I am not sure of the correct behavior for these two items. The PriceHighDuringPosition and PriceLowDuringPosition return -inf until the position experiences a high or low different from the entry price. I would expect an initial default to a price value like the entry price. Is this the correct behavior? It does not cause any errors in my code but it does skew my calculations by not having a value until after a high or low different from the open price is experienced. Thanks, Richard |
[2022-05-30 08:48:42] |
Not sure you would see those particular values. We would think they would be 0 or DBL_MAX. DBL_MAX would indicate that the variables are in unset state. The entry price does not set those variables.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-30 08:49:03
