Date/Time: Fri, 03 May 2024 18:44:13 +0000
Question About sc.ChartTradeModeEnabled Variable
View Count: 349
[2022-05-16 15:45:50] |
Tony - Posts: 460 |
Wonder if it is possible to make sc.ChartTradeModeEnabled Variable both read and write, instead of read only? The reason being is that, I am not able to uncheck "Show Order and Position" when Chart Trade Mode is on, neither able to change the length of showing position line, I have some studies showing information around position level and always have a line across them, I am hoping that at least I would be able to turn Chart Trade Mode on and off with ACSIL Thanks so much! P.S. Not sure which one would be easier for development team: 1, making sc.ChartTradeModeEnabled read/write 2, having an option that position line could be drawn underneath maingraph and subgraph I will be very happy if either one of them can be achieved. Thanks again! Date Time Of Last Edit: 2022-05-16 22:54:46
[2022-05-16 23:03:22] |
Tony - Posts: 460 |
Solution found, Chart Settings -> Trading -> Trade Drawings Left Align % Please ignore the original post. Thanks again for your hard work!! |
[2022-05-17 09:51:09] |
We will look into making this read/write: sc.ChartTradeModeEnabled
[2022-05-26 11:04:03] |
We need to add a new ACSIL function for this. This will be out in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-26 11:04:08
