Date/Time: Sat, 24 Oct 2026 00:05:20 +0000
ColumnsCount (Tile as Grid setting) now showing
View Count: 848
| [2022-05-16 13:42:47] |
| User725043 - Posts: 49 |
in Version 2383 64bit, where is the setting to set the Columns Count? Following the instructions from here: General Settings Window: Columns Count (Global Settings >> General Settings >> Windows >> Window Tiling) but unable to find it in Global Settings >> General Settings >> Windows >> Window Tiling |
| [2022-05-16 14:15:35] |
It is there. Make sure you scroll down to the bottom of the list if necessary.
