Date/Time: Wed, 29 Jun 2022 00:46:21 +0000
Custom session times indicator
View Count: 82
[2022-05-14 15:05:34] |
User176191 - Posts: 10 |
Hello Is there an indicator that can build custom session times drawn as a horizontal line in chart region 2 like in the image below? Regards https://www.tradingview.com/x/2VKZVl75/ |
[2022-05-16 16:15:30] |
John - SC Support - Posts: 17012 |
You could use multiple copies of the Horizontal Line at Time study and put them in a separate region (Region 2 for instance). You would just have to compress the scale very far down in order to make the lines show up at the same level, as you have to assign the line level to a variable item, such as the Last price. Refer to the following: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=306&Name=Horizontal_Line_At_Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
