Date/Time: Sun, 19 May 2024 04:56:36 +0000
[User Discussion] - Stop-limit order
View Count: 1038
[2014-04-29 10:35:15] |
User96105 - Posts: 113 |
Hi, I’m getting a little confused with stop-limit orders… Using Rithmic data in Sim mode I’m testing stop-limit orders with a -4.00 primary offset. So for example, using this order type I want to place a limit order to buy at 16400 (YM) when the price hits 16464 as I’m expecting a quick pull-back. But with the order placed at 16464 I’m filled immediately price hits 16464. Also I’m not seeing any visual information that a stop-limit order is active (I’m only seeing a stop). Am I doing something wrong? Thanks |
[2014-04-30 08:50:47] |
Refer to the documentation here about Stop-Limit orders: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#StopLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-30 09:08:46] |
Thank you, but this doesn't appear to be working as specified if the order is being filled immediately at the stop value rather than at the limit price?
[2014-04-30 09:09:25] |
I'm on version 1119
[2014-04-30 09:11:18] |
It is working properly. Search the Internet for more information about Stop-Limit orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
