Date/Time: Wed, 01 May 2024 21:33:42 +0000
Cant load CB and study that was sent to me
View Count: 289
[2022-05-12 19:41:57] |
User449884 - Posts: 136 |
Getting message that this chartbook is not valid, and when i load teh study it wont show up in my analysis tab
Private File OR_BreakOUT_MultiDOM.Cht - Attached On 2022-05-12 19:41:47 UTC - Size: 3.75 MB - 107 views |
[2022-05-12 20:47:25] |
John - SC Support - Posts: 31283 |
Both of these are too old to be used on a current version. One thing you can do is ask whomever sent them to you to update their system and update the Chartbook and Study at the same time. Otherwise, you can refer to the following for a way to try and read an old chartbook: Chartbooks (Workspaces): Opening Older Chartbooks The custom study needs to be recompiled to work with newer versions. There is no workaround for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
