Date/Time: Fri, 26 Apr 2024 16:40:31 +0000
What am I doing wrong`?
View Count: 360
[2022-05-11 17:32:41] |
John - SC Support - Posts: 31147 |
We are guessing that you are referring to your Point of Control and Value Area lines and the fact that one of each of them is extending all the way across the chart. The reason for this is because in the Extend Point of Control and Extend Value Area Inputs you have selected Until Future Intersection, and those particular lines had not intersected with another profile until later. If you just want the lines extended for the period, then select End of Period for those Inputs. If it is something else you are looking for, then we need more information on what exactly you are seeing different and what you want to see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-12 10:17:20] |
ainvestment - Posts: 3 |
Good day Sorry that I have to disturb again. At the bottom of the time unit is displayed different end times, how can I fix this? I think that is not normal, right? Thanks |
komisch.png / V - Attached On 2022-05-12 10:17:09 UTC - Size: 59.96 KB - 102 views |
[2022-05-12 11:20:08] |
With the second screenshot you see now what I meant exactly, with the guy on Youtube is Value Arena somehow perfect and hits the candle and with me is the somehow below although I have set 68, somehow the whole still does not fit. Thank you very much |
Komisch2.png / V - Attached On 2022-05-12 11:20:07 UTC - Size: 410.09 KB - 113 views |
[2022-05-12 15:16:26] |
With regards to the times that are showing, that can occur. It just depends on what can fit in given the spacing, and sometimes it is not consistent. With regards to the Value Area lines, we do not understand why you would expect to have the lines match up to the High or Low of a bar. If that occurs, it is just accidental. Refer to how the Volume Value Area Lines are Calculated here: Time Price Opportunity (TPO) Profile Charts: Volume Value Area And, if you think they are not correct, then refer to this section: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
