Date/Time: Fri, 26 Apr 2024 15:13:52 +0000
AMP market data delayed
View Count: 353
[2022-05-11 16:09:28] |
User404805 - Posts: 2 |
I want to use Denali data while routing orders with CQG as Amp does not offer your Teton direct CME service yet. I had it setup where I had to switch data feeds to execute trades and when trying to integrate it now I have delayed Denalie data (2min) and no CQG data. What steps need to be taken to have Denali data on my chart and orderbook while executing trades through CQG?
[2022-05-11 17:25:49] |
John - SC Support - Posts: 31140 |
You have the Denali data setup correctly, but it looks like you are not connected to your CQG account. To connect your Sierra Chart to your CQG account go through the setup instructions at the following link: CQG Trading Platform Service: Setup Instructions After that is done, then you need to update the symbols in your chart to be the ones that are used by CQG. To do this, open your Chartbooks and select Edit >> Translate Symbols to Current Service. After that you will be setup to trade through CQG and be getting your data from the Denali Exchange Data Feed. To verify your data is from us you will see an [M] after the symbol, refer to the information here: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
