Date/Time: Sat, 18 May 2024 23:41:55 +0000
How to get additional data for a stock?
View Count: 873
[2014-04-29 01:13:36] |
The Stealthy Trader - Posts: 162 |
This hardly ever happens. A new stock for me, HK, is only showing 3 Days of Data. This isn't a Global Settings issue as every other stock is fine. I went to CS and I couldn't change the range from anything more than the 3 days included. Looked through every menu and can't find anything that will fix this issue for this specific stock. Any suggestions? Thanks so much, J. |
[2014-04-29 01:35:30] |
Refer to help topic 6: Http://www.sierrachart.com/index.php?l=doc/helpdetails6.html If that does not help, then use the Sierra Chart Historical Data service for the data: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html We got 10 years of daily data and about 2 years of Intraday data for HK without a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-29 01:36:02
[2014-04-29 01:40:03] |
Yup.."Delete Data and Download" got it done.. As usual, thanks for the speedy reply! Jonathan |
