Date/Time: Wed, 01 May 2024 21:33:23 +0000
Chart DOM Settings
View Count: 347
[2022-05-10 14:23:00] |
User402365 - Posts: 9 |
Hi! Under Trade - Chart DOM Settings I have my order types set to Buy Stop-Limit for both the Above/Equal Last for Chart DOM and also Below/Equal Last for Chart DOM. When I'm trading in SIM, I can click on the buy column in the DOM at a price that is LOWER than where it's currently trading and when price retraces back to my order, I get filled. That's working perfectly. However, when I'm trying to place the exact same trade LIVE, I get an error message immediately upon entering my order on the DOM. The error message is a REJECT order message that says "Buy order stop price must be above last trade price." Do you know why LIVE isn't working the same as SIM and what I can do to fix this? Thanks so much.
[2022-05-12 17:45:59] |
Sierra_Chart Engineering - Posts: 14173 |
Refer to the documentation here: Order Types: Stop-Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
