Date/Time: Sun, 19 May 2024 04:37:33 +0000
WOODIE CUSTOM STODIES
View Count: 1459
[2014-04-28 19:54:10] |
User43531 - Posts: 5 |
How do I enable "WOODIES CUSTUM STODIES"? Thank you |
[2014-04-28 21:21:16] |
Bedhog - Posts: 168 |
http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php Save the file called "Woodies for Range Charts.stdycollct" in your ..\data\ folder. Be certain to keep the extension named properly. Open a new blank chart Select Analysis; Woodies for Range Charts Viola Date Time Of Last Edit: 2014-04-28 21:23:30
[2014-04-28 21:39:03] |
There is another part to this and that is you need to wait until we have a new release out later today. The service package you are using does not support all of the Woodies studies but that will be changed in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-01 08:18:41
[2014-05-01 08:17:55] |
Sierra Chart does support the Woodies custom studies. Please do the following: Locate and download the "Woodies" Study Collections from this page: https://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php Update Sierra Chart to the latest release by selecting Help >> Download Current Version. Keep in mind that we have not updated the Woodies studies for at least 2 years and there are no plans to do so. So therefore they are definitely out of date and may not be completely what you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
