Date/Time: Sat, 18 May 2024 22:26:48 +0000
Gap on Chart everytime I login
View Count: 929
[2014-04-28 19:15:50] |
User60501 - Posts: 8 |
I get a gap in my chart every time I log in to my account. I have used the delete and reload feature but it does not work. http://www.sierrachart.com/image.php?l=1398712453296.png It will create a gap at whatever time I log in. |
[2014-04-28 20:50:34] |
Historical data for CQG is 10 minute delayed. This is explained in the What Is Included section here: http://www.sierrachart.com/index.php?l=doc/CQGTrading.php#Included By using the Sierra Chart Real-time Exchange Data Feed you get real-time historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
