Date/Time: Mon, 29 Apr 2024 07:19:26 +0000
Lock Fill Space Will Not Disable
View Count: 1718
[2013-04-26 16:16:47] |
There may be a study on the chart that is controlling the space on the right side. Select Chart >> Go to End of Chart. If that does not help remove the studies one by one and try going to the end of the chart to see which one is controlling the fill space.
