Date/Time: Mon, 20 May 2024 13:48:35 +0000
cqg feed not updating after update1128
View Count: 908
[2014-04-28 13:57:38] |
fhvtrading2 - Posts: 11 |
I transfered fm ilq to advantage futures recently. after yesterdays update i can connect to the feed but my charts do not update on the es symbol.last week everything was fine. havent yet installed the older version to see if the version is an issue. do you have an insight. when i disconnect and connect it downloads the data but there are no live updates. kind regards, fhv |
[2014-04-28 15:36:43] |
Restart Sierra Chart. Open a chart for the ES and provide a copy of the Message Log, by following these instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
