Date/Time: Tue, 17 Nov 2026 10:13:18 +0000
Chart calculation order?
View Count: 844
| [2022-05-02 21:50:55] |
| j4ytr4der_ - Posts: 947 |
Are charts processed in their number order? So Chart #1, then #2, then #3, etc.? And how does this interact with study calculation order between charts. such as using price/overly on numerous charts, etc.? I've read everything I can find on this topic but haven't quite been able to get a clear answer... appreciate any insights. Thanks! |
| [2022-05-04 16:13:24] |
| Sierra_Chart Engineering - Posts: 25432 |
The calculation order is random when not using this option: General Settings Window: Use Controlled Order Chart Updating (Global Settings >> General Settings >> Charts >> Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-04 17:47:34] |
Wow random?? That's a bit shocking. OK so with that option enabled, what is it? Numeric order? Something else?
