Date/Time: Mon, 20 May 2024 16:36:37 +0000
[User Discussion] - use two SC with CTS
View Count: 872
[2014-04-27 09:57:22] |
natanibz - Posts: 131 |
Hello, is it possible to use simultaneously two SC with CTS ? (in the same pc) Thanks |
[2014-04-28 18:00:44] |
There is no restriction on the Sierra Chart side with this. We do not know what restrictions CTS might have.
