Date/Time: Thu, 02 May 2024 14:22:09 +0000
message log pop up
View Count: 2199
[2013-04-26 15:29:08] |
Frontrunner - Posts: 20 |
hi support at the end of every 5 minute bar I am getting this message pop up. http://screencast.com/t/LemuWE1UE i tried "delete and download and rac" ....still happens any input would be appreciated.....thanks |
[2013-04-26 17:05:56] |
Check the settings for the Study and Subgraph To Reference input with the study you have named DV.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-26 17:06:34
[2013-04-26 18:34:05] |
thank you support that was a big help....found it and it works fine!
