Date/Time: Mon, 20 May 2024 18:57:28 +0000
Scanning charts
View Count: 893
[2014-04-26 00:57:32] |
Litz - Posts: 131 |
Is it possible to increase the amount of time each individual chart appears on screen while scanning, so that each chart appears for say 5 or 10 seconds? disregard I just assigned a keyboard shortcut that works
Date Time Of Last Edit: 2014-04-26 01:04:56
[2014-04-26 23:40:43] |
Yes. Each individual chart now has its own Chart Update Interval which can override the global setting. So you will want to set that to 10000 ms. This is in Chart >> Chart Settings >> Advanced Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
