Date/Time: Mon, 20 May 2024 13:48:35 +0000
trading studies
View Count: 1030
[2014-04-25 23:11:59] |
trader46 - Posts: 18 |
trading closed profit/loss trading daily profit/loss trading maximum drawdown trading maximum runup all of these studies used to plot by points , and now seem to be plotting currency...example: trading closed profit/loss would plot 6 for 6 points....now is plotting #300 for ESM4, unless i imagined this... I am sure they plotted by points before.. regardless... is there a way to plot by points ticks or currency with these studies??: Thanks |
[2014-04-25 23:32:06] |
and just to add ...i have under chart settings >>advanced settings >> position profit/loss set to points(P)
[2014-04-26 00:25:10] |
What version of Sierra Chart are you running?
[2014-04-26 09:42:41] |
i am running ver. 1127 and it was after i updated from ver. 1115 that i noticed this
[2014-04-26 10:08:43] |
We will fix this.
[2014-04-26 10:23:30] |
We have looked into this now. And we do not see a problem. The calculations are correct according to the Profit/Loss setting in the chart. We think the solution is simply going to be to remove the Trading Profit/Loss studies from the chart and add them again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
