Date/Time: Sun, 18 Oct 2026 03:59:57 +0000
curser value crosshair
View Count: 752
| [2022-04-21 17:46:11] |
| George Slezak - Posts: 40 |
no chart values show when curser value crosshair is enabled
| [2022-04-21 20:12:38] |
| John - SC Support - Posts: 48239 |
If the problem is that you are not getting values showing in the Price and/or Time scales, then refer to the following settings: Chart Drawing Tools: Show Y Value and Time Boxes (Tool Settings >> Chart Values >> Chart Values If the problem is that you are not getting the Tool Values Window (regular or compact), then refer to the following: Chart Drawing Tools: Tool Values Window If a Tool Values Window is selected, but not showing up when the crosshair is active, then refer to the following: Chart Drawing Tools: Cannot See Values Windows? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-21 23:56:52] |
thanks
