Date/Time: Sun, 05 May 2024 03:44:08 +0000
referencing study with displaycement 1 receive 0 value
View Count: 1174
[2014-04-24 14:32:09] |
namlem - Posts: 94 |
Hello SC team, From the intraday chart I'm referencing daily chart's moving averages, which are displaced by 1. The problem is, that sometimes on intraday chart I have 0 values at row 3.. how is that possible, since I'm referencing yesterday's values and they are not changing? Since other studies refering this value all calculations getting wrong automatically.. I tried both and nearest match and containing match, see attached for more details.. |
Private File Private File Private File Private File |
[2014-05-04 17:41:01] |
Hi SC fellows, is there any news on this topic? |
[2014-05-05 21:46:06] |
We apologize for the delay. We will be looking this over this evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-07 07:22:01] |
We have not had time to go over this in detail, but a quick review shows that you should be using Copy Source Data to Latest Corresponding Destination Bar : http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s118 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-14 09:09:39] |
Took me a while to identify the problem one more time.. unfortunately it still exists. Please look at the screenshot attached. This time Study with displacement 1, referenced in other chart with Use Latest Value from Corresponding Timeframe and Nearest Match options. |
Private File |
[2014-05-23 06:29:56] |
Our schedule is so busy we have not had time to look at this in detail, but if what we suggestion is not helpful, then you need to use Fill Blanks with Last Value. Really with the complexity of what you have, we cannot spend the time to understand exactly what you are doing and why exactly this is occurring in your scenario. The study does have inputs to solve these kinds of issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
