Date/Time: Sat, 24 Oct 2026 21:03:12 +0000
Values in Number Bars
View Count: 783
| [2022-04-17 11:42:53] |
| User402365 - Posts: 9 |
Hello, I am using a 2000 tick bar chart for the ES and have loaded the Numbers Bars study. It seems to be working fine, however, the values in each of the bars only show up for approximately 10 days. Anything farther back than that and the numbers all appear as zeros. Is there a way to get the actual numbers to appear for several months back? Thanks so much. |
| [2022-04-18 15:44:50] |
| John - SC Support - Posts: 48317 |
From what we see on your account, you just started getting the data from the Denali Exchange Data Feed on April 4, 2022. Therefore, it sounds like what you are seeing is the historical data from CQG prior to these past 14 days. What you need to do is to delete and redownload all the data so that it is all from our Denali data. Refer to the following instructions for how to delete and download the data in the chart: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
