Date/Time: Mon, 20 May 2024 22:06:18 +0000
DLL Load Error. Says Missing But It's Not.
View Count: 1844
[2014-04-24 01:10:12] |
cmet - Posts: 538 |
I have a dll file from a custom study and though it's present in the /data directory, I'm getting the Windows error code 126: The specific module could not be found. Is there a solution to correct this? Error: http://s30.postimg.org/4739xw6v5/error.jpg dll in directory: http://s23.postimg.org/tixppkr7v/dll.jpg |
[2014-04-24 02:11:04] |
Do you know who created the DLL and what version of Visual C++ they used? This problem is usually because there is another DLL it depends upon which is not present on the system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-24 02:31:11] |
cmet - Posts: 538 |
The SCMisc.dll is from the ATR Bands in the Custom Study menu (from this post:ATR Bands) However, when I go to Analysis > Studies > Add Custom Study - the error fires immediately before I even add anything. |
[2014-04-24 03:35:07] |
There is no need to use that DLL. You can add the ATR Bands through Analysis >> Studies >>Add Custom Study >> User Contributed Studies.
[2014-04-24 11:51:34] |
cmet - Posts: 538 |
I'm not using the study at all. That's the problem. The error pops up after I click the Add Custom Study button. Trying to find out why the error keeps firing before I add anything. The error says the module cannot be found. It's there. Why is SC looking for it every time I click the Add Custom Study button? |
[2014-04-24 12:03:35] |
cmet - Posts: 538 |
This is actually being caused by this: http://www.sierrachart.com/supportboard/showthread.php?t=37616 RTscanVolume Had to delete it. Though there are tools in there that are very useful for seeing value areas within bars. |
[2014-04-28 08:11:03] |
ganz - Posts: 1048 |
pst Hi Had to delete it
try to recompile it using *.cpp |
