Date/Time: Thu, 16 May 2024 10:59:56 +0000
Caught an exception during the processing of a timer event
View Count: 1730
[2014-04-23 22:29:41] |
Lawrence B - Posts: 11 |
I am using Interactive Brokers and continually get the above message during login. Sometimes if I log out of Sierra and log back in it will go away. What can I do. I have downloaded the latest copy of SC.
[2014-04-23 22:44:49] |
Refer to help topic 17 here: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html To isolate the problem, remove all studies from the charts and see if you still encounter it after restarting Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
