Date/Time: Thu, 02 May 2024 10:44:08 +0000
compiler question
View Count: 1578
[2013-04-26 06:02:39] |
user6275 - Posts: 13 |
Ok, havent upgraded in a while, why is my source code now giving me this when i compile? This is my fault..have fallen behind... thanks Error message: -- Starting build of Custom Studies Source File: Automator.cpp. -- 23:59:09 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\SierraChartTransActMA\ACS_Source\Automator.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\SierraChartTransActMA\Data\Automator.dll" C:\SierraChart\SierraChartTransActMA\ACS_Source\Automator.cpp: In function 'void scsf_AutomatorOn(SCStudyInterfaceRef)': C:\SierraChart\SierraChartTransActMA\ACS_Source\Automator.cpp:440:241: error: expected ')' before ';' token -- End of Build -- 23:59:11 |
[2013-04-26 06:21:11] |
What is the code in this file at that line number: Automator.cpp:440 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
