Date/Time: Thu, 16 May 2024 09:31:01 +0000
Detached chart with different time period but same symbol; questions
View Count: 917
[2014-04-23 16:04:34] |
User78621 - Posts: 2 |
Q 1. I saw this issue addressed but not resolved. How do I place a tool bar on a detached window? Q 2. I have the above chart setup and draw a line, for example, on a daily chart but want it to show and be updated as I change it on the corresponding hourly chart. How do I do this without deleting the hourly and creating a duplicate chart? In other words, I want to be able to move my drawing tools on either chart and see the change on both charts. How do I do this? Q 3. On year charts, I want to see more data displayed. I have changed the date settings, bar displayed, etc. with little affect. Why? Q 4. When using a year chart,if I attempt to "spread the bars" (increase the distance and move to the right) the display removes all but the last bar and makes it impossible to regain them without toggling through lower time periods. Appears to be a bug. Please advise fix. Thanks |
[2014-04-23 17:14:17] |
1. This is not currently supported. 2. This is partially supported. Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html 3. What is the symbol of the chart? 4. Select Chart >> Goto End of Chart. Or press on the left arrow on the scrollbar at the bottom of the chart to remove the space on the right side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
