Date/Time: Fri, 26 Apr 2024 14:34:07 +0000
ICE Data
View Count: 697
[2022-04-05 14:58:39] |
User666529 - Posts: 4 |
Hello, I am using SC Version 2376. Since this week I do not receive intraday updates for any ICE Future (e.g. CCK22-ICEUS or KCK22-ICEUS) in my intraday Charts. What do I have to change that there I will receive again delayed data for them? |
[2022-04-05 15:09:12] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Our understanding is ICE data at this time is only going to be up-to-date as of the prior day. These are the ICE market data rules. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-07 09:15:10] |
User197029 - Posts: 45 |
I have the same problem. It used to be snapshot data for ICEUS (unfortunately not anymore for ICEEU) but now even for my ICEUS tickers I do not receive any values (for example for the Footprint charts which are all just showing a bunch of zeroes (see attached)). It seems to still work for some other users though. I have tried to roll-back SC to an earlier version 2363 but same issue. Any idea please? |
07-04-22--111421 --2508.jpg / V - Attached On 2022-04-07 09:14:54 UTC - Size: 95.83 KB - 93 views |
[2022-04-07 13:47:12] |
Yes this makes sense, the ICE data is only 1 minute data now. We are no longer providing ICE data ourselves.
[2022-04-07 13:49:59] |
When you say 1 minute data now what does this mean? shouldnt we be able to see the volume numbers on the chart (at least the next day?) thanks
[2022-04-07 14:14:14] |
The minimum time frame is 1 minute per bar, and there is no Bid Volume or Ask Volume.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-07 14:14:20
[2022-05-20 10:49:04] |
User130862 - Posts: 19 |
So no more ICE data no matter what package you subscribe?
[2022-05-20 11:29:01] |
Historical ICE data is available from Sierra Chart. This is all.
