Date/Time: Fri, 04 Jul 2025 00:20:04 +0000
Unable to move stop orders with the shortcuts
View Count: 896
[2022-03-31 16:27:01]
User697865 - Posts: 6
Unable to move stop orders with the shortcuts assigned to 'Stop Order Tick Up/Tick Down'. I can place stop orders using shortcut keys but i cannot move them using shortcut keys.
[2022-03-31 18:06:44]
John - SC Support - Posts: 40745
The 'Stop Order Tick Up/Tick Down' shortcuts only work on Attached orders. If you have a separate Stop order, then it will not work on those.
[2022-03-31 18:39:56]
is there an another way to move the stop orders using keyboard shortcuts?
[2022-04-01 08:31:30]
We have to look at adding a new keyboard shortcut for this.
[2022-08-29 16:27:19]
User809555 - Posts: 11
Yes please add this shortcut, I would love to have that!
[2023-08-21 05:59:32]
User273277 - Posts: 70
I need to do this also. Has this been scheduled for addition into SC?
[2023-08-21 16:19:33]
There are keyboard shortcuts for the following:
- Non-Attached Limit Order Tick Up
- Non-Attached Limit Order Tick Down
If these are not what you are looking for, then there has not been any additional work on this.
[2023-08-21 19:23:41]
Thank you for the update John.
Unfortunately the trading keyboard shortcuts for non-attached limit order tick up/down do not move buy-stop orders.
This would be a fantastic addition to the trading hot keys.
Have a great day.
[2023-12-11 16:17:02]
franklinian - Posts: 4
I vote for this feature to be added also. Thank you.
[2024-06-27 11:55:20]
User631384 - Posts: 2
I would love to see this feature as well.
