Date/Time: Fri, 30 Oct 2026 04:58:03 +0000
[User Discussion] - Changing and saving the number of contracts on the DOM
View Count: 1069
| [2022-03-29 18:22:59] |
| User820595 - Posts: 9 |
I open FILE > OPEN TRADING DOM FOR CHART > Set Tab to change the number of Contracts to Trade. When I close the DOM and then Reopen it reverts back to the Default Quantities. How can I save the changes? |
| [2022-03-29 18:31:45] |
| John - SC Support - Posts: 48369 |
In order to save the changes you have to not close the Trading DOM. Rather, you need to keep the Trading DOM open and save it as part of your Chartbook. Then, whenever you open your chartbook, the Trading DOM will be open with the values as you had previously set them. Otherwise, each time you close the Trading DOM, you are closing the chart for which the Trade Window is associated and when you open it again, you have a new chart therefore you get the default Trade Window information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
