Date/Time: Wed, 01 May 2024 01:26:45 +0000
CLR version
View Count: 915
[2014-04-22 14:22:42] |
Dennis B. - Posts: 263 |
Running version 1107, is it ok to switch to the latest Non-CLR version. I don't want to go backwards. thx... |
[2014-04-22 14:56:59] |
Yes it is OK.
