Date/Time: Sat, 04 May 2024 07:05:31 +0000
IRONBEAM how to log in MONTHLY to get non delayed data SIERRA CHART
View Count: 639
[2022-03-29 12:23:10] |
User220914 - Posts: 239 |
Hi, I was wodnering how to log into "IRONBEAM LIVE acct" in order to do my duty for the CME of logging into a live trading account in order to get the priviledge of actually seeing my real time quotes live instead of delayed. I understand this is a CME requiremnt not SIERRA CHARTS. is there a work around for logging into live accounts through SIERRA that do not provide data? How do i go about logging into IRON BEAM through sierra without utilizing your teton order routing. I can only have 1 trading platform with Ironbeam at a time and am utilizing another platform right now instead of teton. Thank you |
[2022-03-29 15:00:49] |
John - SC Support - Posts: 31362 |
Is your account with IronBeam setup to use either CQG or Rithmic for the order routing?
[2022-03-29 17:54:51] |
no it is not but i can see if i can get it set up that way
[2022-03-29 18:26:30] |
In order to validate your status as a non-professional, we need to be able to connect Sierra Chart to your trading account. We only have support for Rithmic, CQG and the Teton Order Routing service. Therefore, if you want to get the Denali data for your Sierra Chart, you would need to be able to make a connection using one of these services. Just make sure if you change the order routing service you are using with Iron Beam, then your other trading system will still work with that service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
