Date/Time: Sun, 19 May 2024 00:28:37 +0000
Save Different DOM Stop/Limit Configurations
View Count: 486
[2022-03-28 14:36:38] |
Alex C Demosthenes - Posts: 38 |
Hello - I would like to know a way to set my DOM such that I can click to open a position with Quantity 2, Limit 8 or 10 ticks, and stop 30 ticks Then, a second position immediately after with a Quantity of 1, Limit of 30 ticks, and stop of 30 ticks Finally, a 3rd position with Quantity of 1, Limit of 50 ticks, and stop of 30 ticks. Ideally, I can have all of these saved and set up so whenever I want to trade, I can click to open with these parameters. Whenever I try now to set OCO Group 1, OCO Group 2, etc, it doesn't save or set my trade up as I want it to. |
[2022-03-28 17:10:12] |
Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-23 14:16:31] |
To add to this... Is there a way, using this same 4-contract configuration described in my original message, that I can get the 3rd position to move stop to break-even after the 2nd position hits target? |
[2022-05-23 16:18:17] |
Refer to the following for how to setup a Move to Break Even: Attached Orders: Move to Breakeven for Stop For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
