Date/Time: Sat, 31 Oct 2026 18:07:49 +0000
How to take a Screen Shot
View Count: 4955
[2022-03-25 16:57:48]
User643426 - Posts: 144
Is there an easy way to take a screenshot of my trading platform with all of my charts open and studies included in all the charts? I would like to document my daily profit/loss on the DOM as well as my Order Fills on the charts.
Also, is there a way to clear all drawings on a chart? I've been removing each drawing individually and it's time-consuming. Thank you.
[2022-03-25 17:19:50]
This depends on how you have your windows laid out. If everything is within the main Sierra Chart window, then you can use any of the Edit >> Screen Images options to get a screenshot.
Otherwise, if you have windows scattered around, particularly if you use multiple monitors, then the built-in Windows Print Screen option works best. Once you hit the Print Screen button, it holds the image and you would need to paste it into some program - such as Paint, Word, PowerPoint, or whatever tool you want to use to save the image.
Refer to the following:
Chart Drawing Tools: Erasing Chart Drawings
